I am trying to set up some unit tests for an add-in I am working on. I have followed the Esri Documentation to a T and everything compiles totally fine. The problem seems to lie in ClassInitialize function provided in the guide where it calls Project.OpenAsync(@{insert project path here}).
When I run my unit tests they always fail at this line and the error says that it is unable to open the project. I am certain that there is a valid project at the path I am giving it. Pro will open the project just fine if I open the project from within pro. The even stranger thing is, if I debug and manually walk through the unit tests as they are executing, the error doesn't happen and the tests pass. But only when I am using the debugger. If I run them normally they will fail every time.
Has anyone else encountered a similar issue while unit testing? I can't seem to find much on this and the things I have tried, have not worked.
