Good afternoon.
I have a simple point feature layer that resides in an Enterprise Geodatabase/SQL Server (SDE). I created the layer to use in Field Maps. It includes various domains and attribute rules that I'd like to retain.
I have subsequently published this feature layer to our Portal as a Map Image (reference registered data) including the feature option so that it can ultimately be edited in Field Maps. This seemed to work fine and I am able to use the data in Portal to create a new Webmap.
The issue I've run into, and can't quite understand, is that after the feature layer was published I am no longer able to edit the feature layer in ArcGIS Pro. Any edits I try to make to the feature layer results in an error - "error 000464 cannot get exclusive schema lock...".
I appreciate why this may be the case but wondering if there is a way around this. Down the road I may, for example chose to make edits to the data or need to make changes to the attribute rules which will be easier in Pro. The only solution I can find is to delete the feature layer from our Portal which seems to remove the schema lock allowing me to edit the data in Portal.
This is not a long term option of course so wondering if there might be something I'm missing here.
A couple of points here
- Versions: Enterprise 11.3 and Pro 3.3
- Our Portal and Server are federated.
Thanks for any advice.
