Dear community,
I have installed Arcgis 10.2.2. (64x) and Python 2.7.9 with Matplotlib and Numpy included by default.
I want to install additional module such as Shapely or Fiona or Pandas (version 64x) using the .whl extension.
The installation using the cmd shell works well and all modules are installed in the directory of ArcGISx6410.2/Lib/site-packages but when I try to import the module in PyScripter using "import Shapely", the IDE doesn't recognize it.
In the Python Interpreter window the following message appears: "** Python 2.7.9 (default, Dec 10 2014, 12:24:55) [MSC v.1500 32 bit (Intel)] on win32. ***" which obviously seems to be the reasons why the x64 Python modules cannot be imported.
I would like to use the x64 version in order to use also arcpy. I wouldn't like to switch to the x32 version
Could you please give me a solution?
Thank you in advance.
Best,
Stefano
