I have a script i have been using for the past 6 months that connects to AGOL and copies content into my Portal. Today the script is unable to connect to AGOL. The script connects using gis = GIS(url="https://amica.maps.arcgis.com/home",username="myUN",password="myPW").
Exception Traceback (most recent call last)
In [9]:
Line 1: gis = GIS(url="https://amica.maps.arcgis.com/home",username="myUN",password="myPW")
File C:\Users\A10713\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\arcgis\gis\__init__.py, in __init__:
Line 637: raise e
Line 576: self._portal = _portalpy.Portal(
File C:\Users\A10713\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\arcgis\gis\_impl\_portalpy.py, in __init__:
Line 237: self.get_properties(True)
File C:\Users\A10713\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\arcgis\gis\_impl\_portalpy.py, in get_properties:
Line 1312: raise e
Line 1292: resp = self.con.post(path, self._postdata(), ssl=True)
File C:\Users\A10713\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\arcgis\gis\_impl\_con\_connection.py, in post:
Line 1517: raise Exception("A general error occurred: %s" % e)
Exception: A general error occurred: maximum recursion depth exceeded while calling a Python object When I check in Fiddler I see the following message for the request.
"After the client received notice of the established CONNECT, it failed to send any data."
Any ideas?
