Hello All-
I am curious to what extent (if at all) digitized direction matters in the Water/Sewer Utility Networks.
A good example would be in a Water Network, I have two water lines that connect to an isolation valve between a well/surface water system. The From/To terminal on one line is set differently than it is on the other, simply because when the lines were digitized, they were not digitized in such a way that the isolation valve was the end vertex for both lines.
I had figured this wouldn't matter- but was curious. There are no network topology errors resulting from this, just trying to satisfy my own curiosity/better understanding of how terminals are supposed to function.
