Hello!
The map has a FeatureLayer with graphics from an array of client-side features, I expect fairly standard behavior: when you click on a graphic object, it appears at the top and overlaps all other graphic objects that are also located on this layer.
Unfortunately, this behavior is not expected by default settings; perhaps there are some tools to control the overlay within one layer?
By analogy with layers, I tried to change the order of graphic objects in the array, but this did not give results.
I also tried setting the orderBy field to the layer and changing the required field for the graphic object when selected
