Hello all,
I have a map with two-point layers and a relational table. I am writing calculation rule to generate a value 'rate' based on relationship and other values, also retrieving
var fQ = $feature.LQ;
var fW = $feature.fW;
var wM = $feature.wM;
var ci = $feature.ci;
var eff = $feature.ec;
var FT = null;
var MatType = null;
// Treat empty values as null
if (IsEmpty(ci)) {
ci = null;
if (IsEmpty(eff)) {
eff = null;
// Fetch related poles based on GLOBALID
var gId = $feature.pGLOBALID;
var rP = Filter(FeatureSetByName($datastore, 'SJ', ['GLOBALID', 'FT', 'Mat'], false), 'GLOBALID = <a href="https://community.esri.com/t5/user/viewprofilepage/user-id/731209">@GID</a>');
// Check if rP is not empty and assign values accordingly
if (Count(rP) > 0) {
var pole = First(rP);
MatType = pole.Mat;
FT = pole.FT;
// Check if either MatType or FT is null or empty, then return default value
if (IsEmpty(MatType) || IsEmpty(FT)) {
return '0'; // Default rate
// Construct the SQL WHERE clause incrementally, handling null values and data types appropriately
var a = [];
if (!IsEmpty(fQ)) {
a.push('fQ = @fQ');
if (!IsEmpty(fW)) {
a.push('fW = <a href="https://community.esri.com/t5/user/viewprofilepage/user-id/186967">@FW</a>');
if (!IsEmpty(wM)) {
a.push('wM = @wM');
if (!IsEmpty(ci)) {
a.push('ci = <a href="https://community.esri.com/t5/user/viewprofilepage/user-id/465295">@CI</a>');
if (!IsEmpty(eff)) {
a.push('ec = @eff');
if (!IsEmpty(FT)) {
a.push('FT = <a href="https://community.esri.com/t5/user/viewprofilepage/user-id/73075">@ft</a>');
if (!IsEmpty(MatType)) {
a.push('MatTYPE = @MatType');
var whereClause = Join(a, ' AND ');
// Filter related units based on the constructed SQL WHERE clause
var relatedUnits = Filter(FeatureSetByName($datastore, 'SLC', ['*'], false), whereClause);
// Check if relatedUnits is not null and not empty, then return the rate
if (relatedUnits != null && Count(relatedUnits) > 0) {
var unit = First(relatedUnits);
return unit.Code;
} else {
}status based on availability of other field values. I am either getting Invalid where clause or integer index expected with unidentifiable code line for errors. I am using different combination of data types as short (ci,eff) and Text (code and FT). I'm trying to calculate relationship value and calculate rate value in the same execution of Arcade expression. Above is the calculation rule attached:
