I have a layout that is using (6) bookmarks that I saved for a series of pages. Each bookmark was saved with a scale that made sense at the time, but each has one thing in common: the scales of each bookmark all fall within the label range I made.
In the Layout tab when I select a map frame the scales are not what I specified when I saved the bookmark (which I understand because the paper space I am using is different than my monitor) and when I try to change the scale it immediately reverts back.
In the element property pane the map frames constraint is set to "None", and when I change it, it quickly "blips" then reverts back to "None".
This is extremely frustrating and I'd really like to understand:
- Why is this doing this?
- How do I fix it?
Because this can't just be a matter of "that's the way it is" or that I'm the only one who has decided to change the scale of a layout page map frame....right????
