Greetings to all, I’m new to Arcade and I have a serial chart in a Dashboard, based on an Arcade expression. To correctly display the data obtained through Arcade, I need some of these calculated fields to contain “null”, instead of “0”, as they did in the original table that was used to build the feature set. The feature set consists of two subsequent “groupby” of fields calculated by multiplying (A1), then dividing (A2).
I’d like to use an expression that could convert the “0”s contained in such specific field(s), all at once.
with A2 = group by([....],({...'A1/m' sum})
I ask if there’s a feasible way to work this out. 'Replace', 'Decode', 'If', 'When' functions seem to have little effect on my trials on the entire feature set.
Thank you in advance
