I would like to store elapsed time as an attribute in a feature class, displayed as HH:MM (drive time, for example). I have tried several approaches, and none of them are great.
- "Text" Data Type - User inputs elapsed time as HH:MM, and an Attribute Rule checks that the input fits this format. Works fine, but won't sort in ascending/descending order obviously, and can't easily add/subtract time from the data. Visually good, but the "data" doesn't really mean anything.
- "Time Only" Data Type - This isn't really appropriate either, as my "time" data isn't wall time, but elapsed time. This field type doesn't allow me to store 0:30, for example. Also, stored time can't be larger than 23:59.
- "Short" Data Type - I have this set to display as ##:##, so if a user inputs 337, this shows as 3:37. This field type allows sorting, which is ideal. But, the underlying data is now pretty meaningless once it's separated from it's nice HH:MM display.
So I'm hoping to come up with a way of entering elapsed time as "HH:MM" in a field that also stores the underlying data in a meaningful way (quantifiable, sortable, etc.). I would be happy to use Attribute Rules to assist with this.
