I'm currently in the process of trying to pull together a 'site checker' which will enable the users to select a site and then find data within a certain distance from that. Pretty simple.
I'm using ExB and the Nearby widget on there allows you to search by line, point or polygon. Perfect. However, this doesn't allow you to export the whole output list with map etc. like the Nearby App does. Also once you add a big number of items into the spatial analysis it really struggles, I'm currently not able to add anymore or actually do anything with the widget without it crashing.
I'm suggesting that the Nearby App has the functionality to be able to draw lines, points or polygons for use with the search or select an existing feature on the map and undertake the search. It seems bonkers that functionality is on one but not the other...
James
