Hello, wondering if someone has any ideas on why this is happening. I have a layer on my AGOL map that is required for an arcade expression. But I don't want users to see or interact with the layer. Right now, I have it on the map - turned on with transparent symbology and pop-ups disabled. This is how I've found it needs to work for the expression to work but remain invisible to users.
The issue is that even with pop-ups disabled on the layer in Map Viewer it can still be selected in Map Viewer and Experience Builder. I'm creating a portal for users to export data on other layers through an Experience Builder app.
Does anyone have ideas on why this is happening? Everything I read says that if pop-ups are disabled then you shouldn't be able to select.
