I have installed long back and been working on few apps. now i would like to upgrade it newer version of 1.13 or uninstall the current version and install newer version
When i try to install newer version using command prompt i am getting below error
Error: listen EADDRINUSE: address already in use :::3000
at Server.setupListenHandle [as _listen2] (node:net:1872:16)
at listenInCluster (node:net:1920:12)
at Server.listen (node:net:2008:7)
at Object.<anonymous> (D:\EXB\arcgis-experience-builder-1.13\ArcGISExperienceBuilder\server\src\server.js:1:3490)
at Module._compile (node:internal/modules/cjs/loader:1376:14)
at Module._extensions..js (node:internal/modules/cjs/loader:1435:10)
at Module.load (node:internal/modules/cjs/loader:1207:32)
at Module._load (node:internal/modules/cjs/loader:1023:12)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:135:12)
at node:internal/main/run_main_module:28:49
Emitted 'error' event on Server instance at:
at emitErrorNT (node:net:1899:8)
at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
code: 'EADDRINUSE',
errno: -4091,
syscall: 'listen',
address: '::',
port: 3000
Could you please suggest
