I'm having some difficulty with ArcGIS Desktop 10.8.2.
When I double-click on ArcMap 10.8.2 the familiar splash screen appears but ArcMap does not open.
I've tried renaming and deleting my Normal.mxt. No change. I've installed and reinstalled the program twice. No change.
ArcMap will only come up if I right click "ArcMap 10.8.2" in the start menu and select More - Run as Administrator. This obviously does not seem right.
In addition, ArcCatalog will not keep a network folder connection when mapped. It goes through the process, appears to add the network drive, but after closing and opening they are gone.
Anyone run into this before and if so HELP!!!
Thank you.
JD
