Not sure if this belongs in Field Maps board or AGOL board, but I have a couple of Field Maps forms that I'm building in AGOL. I have multiple layers, all on the same hosted feature layer. All settings are the same as far as I'm aware for both of the layers that I am playing with currently. I have one line layer called "Main" and a point layer called "Fitting". I'm building in auto-incrementing IDs for each of these layers, and was able to test and get the Main id system working. I switched to work on the fitting layer, and after my first expression was written, I lost the ability to edit the calculated expressions. the three dots that you would select to "edit arcade" are just missing. They are still there for all of my other layers, and the only layer that seems to be affected is the fitting layer. This is making it very difficult to test what I am doing, as I cannot open the expression back up to edit anything. Has anyone seen this before? It is driving me mad! Screenshots from the same screen on different layers attached. I have tried this in both the field maps designer module, and from the "Forms" section in map viewer. They both yield the same results.
Any help appreciated.
Damon
