When I try and see the differences between one moment and another using Branched Versioning (through the REST API), I can only see the differences of the latest version that was checked in.
Workflow:
- Edit a feature class in one version
- Rec and Post the version
- Edit a feature class (or same) in another version (could even be the same version)
- Rec and Post the Version
- Try and view differences of the default version via the REST API
- Start reading
- set the from moment to the time prior the time of the first Rec and post (from step 2 above)
- get differences: example url:
Https://gisserver.com/arcgis/rest/services/editingservice/VersionManagementServer/versions/B473F418-9G04-41AC-B3CC-58F7843k1A1/differences?sessionId=%7B956BA9D6-B94D-4DD0-A784-738B90D96EA9%7D&fromMoment=%221%22&moment=&resultType=objectids&layers=&async=&f=json
sessionid: 1701977451347
fromMoment: "1701977451220"
resultType: objectids
The return set of differences comes back with ONLY the changes from the second Rec and Post (from step 4 above).
Is my process correct for obtaining the differences from multiple rec and posts? Is this even possible?
I'm using ArcGIS Enterprise 10.9.1
Mike
