Hello everyone,
I need to update a 10.6.1 base deployment to a new machine, as well as updating to Enterprise 11.2. I understand that I could use the Join Site method and swap the machine out without an issue. And from there, maybe attempting an in-place upgrade to a newer version of enterprise.
I was instead considering the webgisdr method, so to keep the new site isolated for testing and then having IT make the switch to the new machine using DNS when ready. In the documentation, I noticed that it says this method is usually used to replicate the environment to a different datacenter. My question is, would I be able to use a webgisdr backup to restore the site to a new machine in the same datacenter? Will it cause any problem with the active site to do this? I understand the Enterprise versions need to be the same, so I would restore the 10.6.1 backup to the new machine, then perform the upgrade, then make the switch in DNS.
Any comments appreciated!
