Hi all,
I would like to create a spatial map series with dynamic tables in ArcGIS Pro version 3.0.5. Two of the tables contains data from feature layer, which is the easy part. However, I would like to add a third table with data from an external table. The table gets daily updated, so it is not possible to add the table as a standalone table to ArcGIS Pro because I need always the newest version. Is there a possiblity to add data in a table from a path? Probably with arcpy?
Thank you all,
Nadja
