Currently customer info (point hosted feature layer) is entered, property boundaries created (polygon hosted FL) and the customer number (an auto-sequence id) is pulled by a spatial intersect in AGO. These two geometries are both related to the same propertyinfo table but was changed from a feature:feature relationship because this relationship type will not work in forms per this blog https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/introducing-related-record-editing-in-map-viewer/.
My set up works okay for the first customer but I need to be able to maintain/ "pull" that customer id for subsequent properties that may be added for the same person? Creating additional customer points would duplicate customers and the auto-sequence arcade script renders the field not editable. I would like for the customer info to be found via search of the map, then a new property feature added. Without a feature-to-feature relationship, I'm not sure how to do this. This portion of the workflow does not have to be completed in Field Maps but needs to be user friendly, hence the forms. I've attached my scratchpad ERD. Thank you so much for any assistance!!
