Hi everyone,
we are trying to integrate the TimeSlider widget in Appstudio, but it seems the widget is not working properly most of the times.
This is a demo code to reproduce the bug, using Esri's services:
import QtQuick 2.7 import QtQuick.Controls 2.1 import QtQuick.Controls.Styles 1.4 import QtQuick.Controls.Material 2.1 import ArcGIS.AppFramework 1.0 import Esri.ArcGISRuntime 100.15 import Esri.ArcGISRuntime.Toolkit 100.15 Item { property real scaleFactor: AppFramework.displayScaleFactor // Map view UI presentation at top MapView { id: mv anchors.fill: parent Map { BasemapTerrainWithLabels {} FeatureLayer { ServiceFeatureTable { id: featureLayer url: "https://services5.arcgis.com/N82JbI5EYtAkuUKU/ArcGIS/rest/services/Time_atlantic_hurricanes_2000_Hosted/FeatureServer/0" } } } // Add a TimeSlider from the toolkit to the MapView TimeSlider { anchors { left: parent.left right: parent.right bottom: parent.bottom } geoView: mv } } }
With this other FeareService the widget loads and it seems to work:
https://services5.arcgis.com/N82JbI5EYtAkuUKU/ArcGIS/rest/services/Hurricane_time_enabled_layer_2005_1_day/FeatureServer/0
The only difference I can recognize in the previous layers is the type of geometry (points vs polylines). Also, in the web version the widget is working properly for both of them.
I am using the latest version of Appstudio (5.5).
Thanks in advance for your support!
