I am working on a project using the ArcGIS Pro SDK. The project contains a MapView, as well as a few custom dockpanes that can show additional information and controls for elements that appear on the map. When I make an edit inside of the dockpane, the edit applies, saves, and shows correctly, but the undo button does not become active. If I click into another pane, however (such as the map view or the contents panel), the undo button activates and even contains the edits made inside of the dockpane as well as other map related edits. If I click back into the dockpane, the undo button disables. is there a way to make the undo buttons behave correctly when inside of the dockpane?
