I have a series of 7 maps created for our 7 districts, and at the bottom of the smart form in Field Maps, there are three calculated expressions. One that generates a unique ID, one that looks at related tables and the parent feature to determine what "Class" the feature should be, and one that looks at related tables and the parent feature to determine what "Status" the feature should be. Until today, this has worked flawlessly for 8 months. In one of the 7 identically maps with identical expressions for the calculated fields, it has stopped calculating. I am also getting an error when clicking on the parent feature that I have never seen before. When I pull the data from the error log, it points toward a calculated expression in the pop up for the parent feature. I have removed that expression from the pop-up, and that fixed the error on the main feature, but the fields within the smart form are still not working. I've gone through the code in the expressions, and see nothing wrong. The "run" function within AGOL field maps designer still works correctly too. I have tried forcing a reload map and turned the expressions off and back on, and I still get the error. Was wondering if anyone has seen this happen, or if someone may have an idea of what to look at. I've looked at all of the "important" fields in the parent feature and the related taables to see if someone has entered some bad data, and I see nothing out of the ordinary. Very odd. If you have some kind of idea, I'd love to hear it.
Damon
