I'm using MDCS provided with Oriented Management Tools for ArcGIS Pro to create and manage Oriented Imagery Catalog.
I've tried to define in the XML configuration file the properties of the OIC in the Property node. But it seems that the MDCS scripts does not take care of this settings or the syntax I have used is wrong.
This is for example a setting I did
<Property>
<properties>'Copyright:text' 'xyz';'Copyright:url' 'www.xyz.com'</properties>
</Property>
I've also tried without the single quote in the tags, but I didn't get any results:
<Property>
<properties>Copyright:text 'xyz';Copyright:url 'www.xyz.com'</properties>
</Property>
I have used both version 2.12 and the latest available on arcgis.com ( https://www.arcgis.com/home/item.html?id=36ee0bbedca64a5a8b68d7c69ab51728).
I'll appreciate your reply to help me what's wrong.
Giuseppe
