Is there a pre-built way to translate between arcpy CIMPopupInfo schema and Enterprise popup schema? Since publishing through Python doesn't maintain popups, I have to access the Portal item after publishing, build the popups, then call update() with the custom-build popup schema. The problem is that the CIM schema and Enterprise schema don't easily align, so I have to write some custom code to build the Enterprise popup. While it's fairly trivial, I'm experienced enough to know that some iteration of popup properties is likely to be overlooked. There's a good start on this Community post, but if an Esri-provided solution already exists, I'd love to use it. Alternatively, is there a page that defines the Enterprise popup schema? The only way I've found to access it so far is to get a Portal item and look through the get_data() return value.
