I have a folder with 1200 "ArcMap Traverse Files" in .txt format. Example of two small lines:
| DT QB |
| DU DMS |
| SP 2618687.126449457 181820.133039019 |
| DD N0-0-0E 0 |
| DD N87-0-0E 0 |
| DD S87-0-0E 0 |
| DD S70-0-0E 0 |
| DD S75-0-0E 1 |
| DD S78-0-0E 1 |
| DD S52-0-0E 1.16227766016838 |
| DD S40-0-0E 2.66867423467692 |
| DD S32-0-0E 3.38859256244759 |
| DT QB |
| DU DMS |
| DD N0-0-0E 0 |
| DD N87-0-0E 0 |
| DD S87-0-0E 0 |
| DD S70-0-0E 0 |
| DD S75-0-0E 1 |
| DD S78-0-0E 1 |
I can import them individually, and each work great... but doing so manually is/will be a pain. I've tried packing multiple into one file, but despite having a stated Start Point in X Y for each new line, ArcGIS Pro 3.1 acts as if the end of the last segment is the start point. I ended up with a continuous line with only the the first at the correct Start Point location.
Any advise?
