I have a HFL which I created to work with a GNSS receiver and has a spatial reference in NAD 1983 2011 to match the coordinate system of the base station we use. That feature class works fine when collecting points with the GNSS receiver. Since then I have found other ways to use the GNSS receiver to collect Utility points for gas valves and water valves. So I created a new HFL based off my existing HFL using the Export Data and Publish tools in ArcGIS Online. When I did this, I noticed the Spatial Reference of the new HFL has changed from NAD 1983 2011 to WGS 1984 Web Mercator (auxiliary sphere) which is fine but now the points on my map are hidden and I can't see them. I know they are there bc the attributes are there in my attribute table and when I select one, it is selected in the map.
Why is this? And How can I fix it?
