Hi there,
I am trying to create Feature layers in Arc GIS Pro comparing two fields. In my case I want to show the Electricity use of a home as the Primary symbology using graduated symbols. I then want to vary this symbology by attribute, for instance whether the home is Owned or Rented. Since I can't seem to vary the symbology by attribute if it is a text field (which would be preferable) I have converted my text fields into numbers, ie assigning '0' to Rented and '1' to Owned.
This works fine in terms of showing the data on the map, but the legend is then confusing as it shows the numeric values rather than the text. I have tried editing the legend in the Contents pane, but sometimes the text will just revert to the numeric value.
Also, where I have a range of values to represent, eg I want to show electricity use by age of boiler (Under 1 year, 1-5 years, 5-10 years, Over 10 years) then the middle values are grouped together in the legend and there doesn't seem to be a way to edit them.
Any advice as to how to resolve this would be appreciated!
Thank you,
Georgina
