I have polygons and points in ArcGIS Pro, most of the points are located close to the limits between polygons, these points that are inside a polygon but very close to the other polygon influence not only the polygon where they are located but also the nearby neighboring polygons How can I count how many points affect each polygon in ArcGIS Pro, that is, the points that are inside the polygon and those close to its border in a distance of 20 meters and how can I list these points that affect each polygon, that is, those that are inside and near the polygon at the desired distance.
One more question, if there is a polygon inside another larger polygon, does this cause a problem when counting the points?
I'm working in ArcGis Pro 3.0.3
