I have an extensive hosted feature layer (points) which I would like to split up into separate hosted feature layers so field crews can work in different areas with individualized field maps based on zones / regions / neighborhoods. Am I missing a way to make one Smart Form and apply it to / within different hosted feature layers / different field map apps? The hosted feature layers will all have the exact same attributes. I'd just like to avoid having to create a redundant smart form over and over again, or make a few hundred bookmarks for the zones. Working in Portal with a Map made in Map Viewer (not classic). Other ideas welcome (copy a json file? / use AGOL Assistant? )! And thank you!
