When trying to get our Pro licensing information from our Enterprise, nothing (NoneType) is returned, even though the majority of our Pro licenses are configured to use our Enterprise accounts.
Is this a known limitation of Enterprise? Is it due to our Enterprise version (10.9.1)? Is it due to the arcgis module version (1.9.1)?
Below is the code I'm using, and based on the Python API documentation the way I read it, this should be doable in both ArcGIS Online and Enterprise. I've tested the same code below on our AGO Organization and it works as expected.
import arcgis
portal_url = '...portal url...'
portal_user = '...user name...'
portal_pwd = '...user password...'
# connect to portal
p = arcgis.GIS(portal_url, portal_user, portal_pwd)
# get pro licensing
pro_licenses = p.admin.license.get('ArcGIS Pro')
print(pro_licenses)
# verify pro licensing is returned
if pro_licenses:
a = pro_licenses.all()
for u in a:
print(u)
When I run the code above on our Enterprise, line 12 returns: None
