Using 3.1, I have almost 5k points that have an attribute filled out for distance from edge of road. When I bring it into Pro, I use stationing or measure of an existing line. This line is not the edge of the road. I was wondering if there was a way to automate moving all these points using a field in the attribute table for the distance from edge of road.
Right now the work flow is selecting edge of road, copy parallel, and snap each individual point to that. These points can vary in distance so you'll have multiple lines that you used copy parallel for and it becomes very time wasting.
Thank you for your help.
