Route event layers that are based on large event tables (>1000 rows) are relatively fast when drawn in the map. But they could be faster.
It's occurred to me that plotting events along a line using M-values is computationally expensive process. There's likely a fair bit of trigonometry being done. And things like multi-part features and true curves would add complexity & slowness too.
Idea:
If an event spans the entire length of the line (F_MEAS = 0 and T_MEAS >= line length) then just use the line geometry from the FC -- instead of plotting the event along the line. If the event only spans a portion of the line, plot the event along the line as usual using trigonometry.
That might improve Route Event Layer performance since using an existing shape would be faster than generating a new one (plotting an event along a line). For example, drawing a feature class in the map is extremely fast -- way faster than a Route Event Layer.
Could the ArcObjects code behind Route Event Layers be optimized using a technique like that, if it's not being done already? (I assume it's not, otherwise I think my Route Event Layers would be as fast as a FC.)
