Hi!
I've run into a problem with my bookmark map series. I'm using a map series to map about 45 different parcels of land owned by about 15 different land owners.
I started with a spatial map series, but I don't need a map for every single tract, just one for every set of tracts owned by a landowner. Also I wanted the map frame to center on a group of tracts, not one individual tract. So I made a bookmark for each landowner by zooming to the selected features and then rounding the map scale up to the next 1,000, and then I used those bookmarks for the new map series.
The problem I am having is that the scale of the map frame doesn't match the scale of the bookmarks, and if I try to change the scale it just switches right back to where it was. For example, for one of my larger tract groups, everything fits neatly into 1:40,000, which is where I have the bookmark set, but the map frame is stuck at 1:65,000 (rounded to 1,000). At that scale, this layout includes the neighbor's property, which is misleading. Worse, it makes the layout look ugly.
Any help here would be appreciated.
