Hi, I am trying to link points in an image taken from a drone to actual points in the map. That is, I want to click on the image, get the pixel position, and use the location, orientation, hFOV and vFOV of the drone to compute the position on the map. I have done all the required calculation already and I am able to do this on a flat terrain (at see level for example), but it becomes very inaccurate when terrain is uneven. To solve this I was thinking about
1) Is there method accepting a line in space and returning the point where the line intersect the surface? I could simply pass the line of sight between the drone and the see level and obtain the actual point seen by the drone.
2) Is there method similar to the ScreenToBaseSurface that does not require to be in first person and accepts hFOV and vFOV?
3) Could I use somehow the ViewShed analysis to obtain information about one single point instead of the analysis overlay output?
3) Any other idea or suggestion about how this could be achieved?
Thank you.
