Allow the beta public notification tool to use Arcade Expressions within the downloads. I noticed it works fine with default fields. However, when I create custom expression using Arcade, the pdf and csv downloads no longer work. The end goal with using arcade in this app is 1) concatenate fields (St#, St Name, Apt...) and 2) Remove the null fields from being visible in the pdf export. If an address field is parsed out and it has no apartment/unit number, the app automatically puts "null" in the mailing pdf.
