I'm looking to make replicable Experiences that can be re-purposed for many different projects by swapping in different webmaps (with different feature services, but sharing the same formatting/schema).
I see that we can create templates and import multiple data sources - but is there any way to swap a new web map / data in place of what's already there? From what I can tell we can't do that, so you have to go through and manually update the data sources for each widget. Am I missing a feature perhaps?
Using the AGO Assistant I duplicated an Experience and swapped out all my template webmap URL's for my new one, and the Experience works perfect, however it then becomes noneditable. This will probably be okay in most instances, but the ability to make a few edits would be better. Wanted to see if anyone had other recommendations.
