It would be great to have a "Save Field Map" option in ArcGIS Pro. This would function similar to the Load/Save expression that is available in tools like Append.
This would be useful for quickly recalling or recreating a field map that was used to reconcile field differences from a past geoprocessing tool run for a new target dataset that has the same set of fields (as the past exercise's target dataset) but different layer name or path.
