I am experimenting with cloning content from ArcGIS Online to Portal. I used the samples from https://developers.arcgis.com/python/guide/cloning-content/#the-cloning-process
I succeeded cloning hosted feature layers, web maps and a web mapping application.
However I'm now running into an error when cloning web maps with this line of code (which I used succesfully before):
cloned_wm = target.content.clone_items(items=[testwm],owner="<portal admin username>")
The response is this:
_ItemCreateException Traceback (most recent call last)
In [9]:
Line 1: cloned_wm = target.content.clone_items(items=[testwm],owner="portaladmin")
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py, in clone_items:
Line 5090: return deep_cloner.clone()
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_clone.py, in clone:
Line 748: results = executor.submit(self._clone, executor).result()
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\concurrent\futures\_base.py, in result:
Line 432: return self.__get_result()
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\concurrent\futures\_base.py, in __get_result:
Line 384: raise self._exception
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\concurrent\futures\thread.py, in run:
Line 56: result = self.fn(*self.args, **self.kwargs)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_clone.py, in _clone:
Line 735: raise ex
Line 2253: raise _ItemCreateException("Failed to create {0} {1}: {2}".format(original_item['type'], original_item['title'], str(ex)), new_item)
_ItemCreateException: ('Failed to create Web Map <name of web map>: 4', None)
I am still trying to figure this out, but not getting anywhere so far. If you have any suggestions, please help!
