Hello, folks
I am very confused about Active-Passive and Active-Active deployment in HA Environment.
My first question:
(do the concept of active-passive and active-active for ArcGIS Server only or it can be applied on the base deployment as a whole unit as this point is very vague in the documentation.
consider this point for the next two questions: I will install arcgis enterprise highly available (active-passive). I say (active-passive) because I have only one license for ArcGIS Enterprise. This is the only point I can understand about the concept of active-passive. That I buy only one license for the two sites.
Second question:
regarding portal installation, when I install the portal on the second machine should join the existing portal or create a separate one. And what about the shared content? will be one directory or separate directories.
Third question:
Regarding ArcGIS Server installaion, when I install the second arcgis server should I join the existing site or create a new one. And what about the config-store and output directory will be the same for two machines or separate? Kindly need help
