code:
String path="/storage/emulated/0/Android/data/003_Topographic.TPK";
Log.i("bryan_test",path);
File file=new File(path);
if(!file.exists()){
Log.i("bryan_test","file does not exist");
return;
ArcGISTiledLayer layer=new ArcGISTiledLayer(file.getPath());
ArcGISMap map= new ArcGISMap(new Basemap(layer));
mapView.setMap(map);
Log:
2022-11-15 00:17:31.634 14426-14426/? I/e.myapplicatio: Late-enabling -Xcheck:jni
2022-11-15 00:17:31.668 14426-14426/? E/libc: Access denied finding property "persist.device_config.runtime_native.use_app_image_startup_cache"
2022-11-15 00:17:31.668 14426-14426/? E/e.myapplicatio: LoadAppImageStartupCache enabled : 1
2022-11-15 00:17:31.668 14426-14426/? E/e.myapplicatio: Unknown bits set in runtime_flags: 0x8000
2022-11-15 00:17:31.669 14426-14426/? I/e.myapplicatio: Reinit property: dalvik.vm.checkjni= false
2022-11-15 00:17:31.669 14426-14426/? I/e.myapplicatio: ReInitProperties: persist.vm.debug.dumpapi= false
2022-11-15 00:17:31.662 14426-14426/? W/e.myapplicatio: type=1400 audit(0.0:40258): avc: denied { read } for pid=14426 name="u:object_r:device_config_runtime_native_prop:s0" dev="tmpfs" ino=17467 scontext=u:r:untrusted_app:s0:c82,c258,c512,c768 tcontext=u:object_r:device_config_runtime_native_prop:s0 tclass=file permissive=0
2022-11-15 00:17:31.699 14426-14426/? D/ActivityThread: Attach thread to application
2022-11-15 00:17:31.733 14426-14449/com.example.myapplication I/ActivityThread: Init compatible state: true
2022-11-15 00:17:31.738 14426-14449/com.example.myapplication D/HwFrameworkSecurityPartsFactory: HwFrameworkSecurityPartsFactory in.
2022-11-15 00:17:31.738 14426-14449/com.example.myapplication I/HwFrameworkSecurityPartsFactory: add HwFrameworkSecurityPartsFactory to memory.
2022-11-15 00:17:31.741 14426-14449/com.example.myapplication D/BehaviorCollectManager: hook process for AI virus second
2022-11-15 00:17:31.743 14426-14449/com.example.myapplication I/BehaviorCollectManager: bindAnalyzerService: huawei.android.security.IAppBehaviorDataAnalyzer$Stub$Proxy@93c9358 pid:14426
2022-11-15 00:17:31.828 14426-14426/com.example.myapplication D/ApplicationLoaders: createClassLoader zip: /data/app/com.example.myapplication-CWcmT41cR9l8JEUb-yoA5Q==/base.apk librarySearchPath: /data/app/com.example.myapplication-CWcmT41cR9l8JEUb-yoA5Q==/lib/arm64:/data/app/com.example.myapplication-CWcmT41cR9l8JEUb-yoA5Q==/base.apk!/lib/arm64-v8a libraryPermittedPath: /data/user/0/com.example.myapplication parent: java.lang.BootClassLoader@6de31f targetSdkVersion: 31 isBundled: false classLoaderName: null sharedLibraries: null
2022-11-15 00:17:32.484 14426-14449/com.example.myapplication I/HwApiCacheMangerEx: apicache path=/storage/emulated/0 state=mounted key=com.example.myapplication#10594#256
2022-11-15 00:17:32.484 14426-14449/com.example.myapplication I/HwApiCacheMangerEx: need clear apicache,because volumes changed,oldCnt=0 newCnt=1
2022-11-15 00:17:32.486 14426-14449/com.example.myapplication I/HwApiCacheMangerEx: apicache path=/storage/emulated/0 state=mounted key=com.example.myapplication#10594#0
2022-11-15 00:17:32.486 14426-14449/com.example.myapplication I/HwApiCacheMangerEx: need clear apicache,because volumes changed,oldCnt=1 newCnt=1
2022-11-15 00:17:32.496 14426-14449/com.example.myapplication I/HwPartIawareFactory: add android.common.HwPartIawareFactoryImpl to memory.
2022-11-15 00:17:32.496 14426-14449/com.example.myapplication I/AwareBitmapCacher: init processName:com.example.myapplication pid=14426 uid=10594
2022-11-15 00:17:32.579 14426-14426/com.example.myapplication I/HwTypeface: updateFont: scale=0.95
2022-11-15 00:17:32.580 14426-14426/com.example.myapplication D/SystemFonts: areFontsVariable: script=Hans
2022-11-15 00:17:32.581 14426-14426/com.example.myapplication I/ActivityThread: finishPreloaded preloadStatus 0
2022-11-15 00:17:32.630 14426-14426/com.example.myapplication D/OpenGLRenderer: disableOutlineDraw is true
2022-11-15 00:17:32.640 14426-14550/com.example.myapplication I/OpenGLRenderer: RenderThread: progress name = [com.example.myapplication], viewCornerType = 0
2022-11-15 00:17:32.645 14426-14552/com.example.myapplication I/iGraphics: [0020080c] pn: com.example.myapplication, p: 14426
2022-11-15 00:17:32.645 14426-14552/com.example.myapplication I/iGraphics: [0030080c] no spt app: com.example.myapplication
2022-11-15 00:17:32.834 14426-14426/com.example.myapplication V/ActivityThread: callActivityOnCreate
2022-11-15 00:17:32.912 14426-14426/com.example.myapplication I/DecorView[]: pkgName:com.example.myapplication old windowMode:0 new windoMode:1, isFixedSize:false
2022-11-15 00:17:32.957 14426-14426/com.example.myapplication I/OverScrollerOptimization: start init SmartSlideOverScroller and get the overscroller config
2022-11-15 00:17:32.957 14426-14426/com.example.myapplication I/OverScrollerOptimization: get the overscroller config
2022-11-15 00:17:33.037 14426-14426/com.example.myapplication W/e.myapplicatio: Accessing hidden method Landroid/view/View;->computeFitSystemWindows(Landroid/graphics/Rect;Landroid/graphics/Rect;)Z (greylist, reflection, allowed)
2022-11-15 00:17:33.040 14426-14426/com.example.myapplication W/e.myapplicatio: Accessing hidden method Landroid/view/ViewGroup;->makeOptionalFitsSystemWindows()V (greylist, reflection, allowed)
2022-11-15 00:17:33.226 14426-14426/com.example.myapplication I/bryan_test: /storage/emulated/0/Android/data/003_Topographic.TPK
2022-11-15 00:17:34.042 14426-14426/com.example.myapplication W/e.myapplicatio: Verification of void com.esri.arcgisruntime.internal.util.j$a.<clinit>() took 630.870ms
2022-11-15 00:17:34.180 14426-14426/com.example.myapplication D/ActivityThread: add activity client record, r= ActivityRecord{90e5701 token=android.os.BinderProxy@d04f517 {com.example.myapplication/com.example.myapplication.MainActivity}} token= android.os.BinderProxy@d04f517
2022-11-15 00:17:34.206 14426-14426/com.example.myapplication I/HwPartMagicWindowFactory: add android.common.HwPartMagicWindowFactoryImpl to memory.
2022-11-15 00:17:34.229 14426-14426/com.example.myapplication D/MouseWheelSynthesizer: mMoveStepInDp: 64, mMoveStepInPixel: 192, mUpTimeDelayed: 100
2022-11-15 00:17:34.231 14426-14426/com.example.myapplication D/ViewRootImpl: ViewRootImpl mIsInProductivePCDisplay: false
2022-11-15 00:17:34.233 14426-14426/com.example.myapplication I/HwPartPowerOfficeFactory: add HwPartPowerOfficeFactoryImpl to memory.
2022-11-15 00:17:34.250 14426-14426/com.example.myapplication D/InputEventReceiver: dispatchInputInterval 1000000
2022-11-15 00:17:34.288 14426-14616/com.example.myapplication I/HiTouch_HiTouchSensor: HiTouch restricted: Keyguard locked restricted.
2022-11-15 00:17:34.288 14426-14616/com.example.myapplication D/HiTouch_PressGestureDetector: onAttached, package=com.example.myapplication, windowType=1, mIsHiTouchRestricted=true
2022-11-15 00:17:34.306 14426-14550/com.example.myapplication D/OpenGLRenderer: disableOutlineDraw is true
2022-11-15 00:17:34.871 14426-14473/com.example.myapplication D/ZrHung.AppEyeUiProbe: not watching, wait.
mainfest:
build.gradle:
plugins {
id 'com.android.application'
android {
compileSdk 31
defaultConfig {
applicationId "com.example.myapplication"
minSdk 23
targetSdk 31
versionCode 1
versionName "1.0"
multiDexEnabled true
testInstrumentationRunner "androidx.test.runner.AndroidJUnitRunner"
buildTypes {
release {
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android-optimize.txt'), 'proguard-rules.pro'
ndk {
abiFilters "armeabi-v7a", "arm64-v8a"
debug{
ndk {
compileOptions {
sourceCompatibility JavaVersion.VERSION_1_8
targetCompatibility JavaVersion.VERSION_1_8
packagingOptions {
exclude 'META-INF/DEPENDENCIES'
sourceSets{
main{
jniLibs.srcDirs=['lib']
dependencies {
implementation 'androidx.appcompat:appcompat:1.3.0'
implementation 'com.google.android.material:material:1.4.0'
implementation 'androidx.constraintlayout:constraintlayout:2.0.4'
testImplementation 'junit:junit:4.13.2'
androidTestImplementation 'androidx.test.ext:junit:1.1.3'
androidTestImplementation 'androidx.test.espresso:espresso-core:3.4.0'
implementation files('libs/arcgis-android-100.15.0.aar')
// implementation 'com.esri.arcgisruntime:arcgis-android:100.15.0'
implementation 'com.google.code.gson:gson:2.9.0'
implementation 'androidx.browser:browser:1.4.0'
implementation 'androidx.localbroadcastmanager:localbroadcastmanager:1.1.0'
implementation 'org.apache.httpcomponents.core5:httpcore5:5.0.4'
implementation 'org.apache.httpcomponents.core5:httpcore5-h2:5.0.4'
implementation 'org.slf4j:slf4j-api:1.7.32'
implementation 'commons-codec:commons-codec:1.15'
implementation 'org.conscrypt:conscrypt-openjdk-uber:2.2.1'
implementation 'net.spy:spymemcached:2.12.3'
implementation 'org.ehcache.modules:ehcache-api:3.4.0'
