I have field workers using a tree assessment survey123 with a tree feature class and related table with their inspections. They use a field map to orientate themselves because the map function in Survey123 is very limited.
I want the popup to show last inspection date and status. In the map viewer on my desktop this shows up as expected: (last inspection date and status are fields in the feature layer, copied from the inspections table during creation)
But in Field maps this shows all kind of extra related fields, including the option to add inspections (Which will confuse my fieldworkers and mess up my symbology) Field maps popup of the same webmap:
So I would like to know how I can disable viewing the related records in the popup of fieldmaps without disabling the popup completely. Making the feature layer and table read only is not an option since they should be able to add inspections using survey123
Thank you for your time reading this,
Regards,
Bert
