I basically want to load some raster data (from GeoTIFF file) and then transform it via a Raster Function.
I created the Raster Function Template in ArcGISPro and then exported it in JSON format.
(Actually exported as XML and then converted to JSON via the Python console using arcpy.management.ConvertRasterFunctionTemplate as I found no way to directly export as JSON).
Now, in the code, when I want to create a RasterFunction instance from the JSON file I always get an Exception saying
Esri.ArcGISRuntime.ArcGISRuntimeException: JSON object key not found.
The documentation of the Runtime SDK (for any language) is vague at best.
When I look at a sample I noticed that the keys in the JSON use snake_case whereas the export from ArcGISPro uses camelCase (or PascalCase).
The sample I'm referring to:
https://github.com/Esri/arcgis-runtime-samples-dotnet/blob/main/src/WPF/ArcGISRuntime.WPF.Viewer/Samples/Layers/RasterLayerRasterFunction/RasterLayerRasterFunction.xaml.cs
I would be grateful for any hint on how to successfully load a Raster Function Template exported from ArcGISPro.
I attached the JSON file with the Raster Function.
I'm using ArcGIS Runtime 100.14.1 and ArcGISPro 3.0
Regards,
Christian
