Hi!
I have a vtpk as basemap and that can be loaded as basemap to my map (2D, wkid 32639 / UTM projection) - fine
I have a second vtpk (same region) with wgs84 web Mercator (AS).
That could be loaded by the map (2D) but not by the scene (3D).
In the mapReady signal is emitted in both cases.
The problem is: basemap is simply not visible.
(minScale/maxScale shouldn´t be the problem)
I that supported? Or does someone knows some limitations?
I am using ArcGIS runtime qt, V100.8 on OpenSuse:
Thanks in advance!
