I have a feature service that I published to my Enterprise Portal's (10.8.1) federated hosting server, and I wanted to experiment with replacing the Survey123 Form published along side it with the smart form capabilities of ArcGIS Field Maps. I installed the ArcGIS Field Maps software on my Portal's server so I could access the web based manager. Looking around ESRI's documentation, I was led to believe that there was a bit more customizability with the smart (calculations, default values, etc). However, in Enterprise a lot of these functions seem to not be available? I copied the published service over to my AGOL site and opened up Field Maps there to find that these capabilities are present in AGOL. (See attached images) The AGOL version even has an entire section for customizing how the app even collects data. So I guess my question is, am I missing anything? Will these capabilities be added to future enterprise portal versions? It strikes me that the Enterprise version of the Field Maps smart form is barely better than a regular pop-up-based attribute editor, while the AGOL smart form is everything I need. Why would ESRI release this app without something as essential to a smart form as a default value?
