I have dynamic paths set up for a set of photos I've added to my map series and if the arcade expression does not result in a valid image path, nothing shows up on that particular sheet, which is fine, but is there a way to evaluate whether the path exists or not and if not, return another path instead? I'm inserting excel tables into the map and for the sheets which have no table, I want an image of an empty table to take its place without having to duplicate and rename the image for every "empty" sheet. Can I do this?
