We have technicians that collect specimens out in the field and records their observations. They then bring those specimens in and we have a biologist that identifies their exact species and then enters that into that same feature. The users collect data using field apps and then the biologist uses a Web App to enter in the species data.
The issues I am having is that the biologist cannot not edit any features unless he is the original creator of that feature.
The settings of the layer that is being edited is set to: Editors can edit all features.
If you open the map that is connected to the web app, you can edit those features no problem. But if you use the smart editor in the web App, it is grayed out as if it read only if you are not the creator of that feature. If you are the creator of that feature, then every thing can be edited as intended. Using the edit widget does the same thing within the app.
I'm at a lost, anyone have any ideas on what may be happening?
Using just AGOL, no enterprise.
