Hi everyone
I use a layer that contains a few thousand areas.
I would need to create a filter to select / download only the areas that contain a set of attributes that I have in an external list (if I wanted I could also load the list in a new layer if needed).
The list I use for extracting areas changes often and contains hundreds of values ...
I would like to ask you if you know a way to create this type of filter, or any advice on how to extract areas based on the value of an attribute. The fact remains that every time I have to extract hundreds of data with different attributod values.
Stefano
