Hi all,
adding the jimu-arcgis dependency in the manifest.json causes the following error in custom widgets. I've tried this with my own code and esri's js-api-widget in Exp.B. 1.6 & 1.7. Is anyone else getting the error?
Uncaught (in promise) TypeError: this.mapView is undefined
updateMapView https://localhost:3001/widgets/arcgis/arcgis-map/dist/runtime/widget.js:1
componentDidUpdate https://localhost:3001/widgets/arcgis/arcgis-map/dist/runtime/widget.js:1
promise callback*componentDidUpdate https://localhost:3001/widgets/arcgis/arcgis-map/dist/runtime/widget.js:1
React 14
u https://localhost:3001/jimu-core/index.js:2
createResizeHandler https://localhost:3001/jimu-core/index.js:2
t https://localhost:3001/jimu-core/index.js:2
React 15
startRenderMap https://localhost:3001/widgets/arcgis/arcgis-map/dist/runtime/widget.js:446
setTimeout handler*execute/Ie/this.startRenderMap https://localhost:3001/widgets/arcgis/arcgis-map/dist/runtime/widget.js:446
componentDidMount https://localhost:3001/widgets/arcgis/arcgis-map/dist/runtime/widget.js:603
React 8
widget.js:1:26069
