I want to run a gdal.translate command via os.system() or subprocess.run() inside a script.
I tested the following ways of running the command:
https://imgur.com/LWC7Sa3service
- Starting python from the command-line:
https://imgur.com/AgQtQsq
As you can see it worked fine in both ways. However if I pass the command inside a script it will not work. The following error occurs when I catch the output of the subprocess.run()-Command:
ERROR 1: PROJ: proj_create_from_database: Cannot find proj.db\nERROR 1: Failed to process SRS definition: epsg:25832\n')
I am using Ubuntu and process the data inside a docker-container. The command is executed somewhere deep inside of the command-chain.
