I have a project that makes use of multiple GDB versions that I use for editing. My mapper also has an identify tool, and as expected it returns the identify results of the default version (default SDE). I saw in the docs that one could use the options property to specify the gdbVersion. So I wrote the following line:
identifyTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">IdentifyTask</SPAN><SPAN class="punctuation token">(</SPAN>systemURL<SPAN class="punctuation token">,</SPAN> versionName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
But the identify is still returning the results from the default SDE version. Does anyone have any experience with this?
Thanks, Naci
